Posted - 25 May 2014 : 18:27:27
We now have available a kit that will replace the possibly old and faded insert on later cars, front and rear screen and side rear quarters. These were originally fitted from c. mid '71 instead of the stainless steel trims. Most screen rubbers that are available only take the insert now. Anyway, the kit which needs to be cut to size (and you will need to keep your existing corner pieces) contains a 12m roll; sufficient to do front and rear screens and side quarters; costs £29 to members and £41 to non-members. the plastic finish is of a good bright quality. Your seal needs to be in good shape, but even if little bits of the retaining groove are damaged it should still fit OK and will brighten up your vehicle. If you would like to reserve one; please let me know. Available at the end of June. Glen. |
