 starts but will not pull
harley95
Posted - 14 Apr 2015 :  20:07:38  Show Profile  Reply with Quote
Hi My 64 Rapier kept cutting out ( pump fault) so i fitted a new Diaphragm off E Bay. Eng now runs but spits through the carb when trying to pull away Points capacitor leads distributor cap and coil have now been replaced, carb removed jets clean so replaced still spits in the carb and discharges unburnt fuel out of the exhaust. Help
jbailey
Posted - 15 Apr 2015 :  11:02:04  Show Profile  Reply with Quote
What kind of carburettor is fitted? Is it the Solex B32 PAIA? If so check the air correction jets, there are two of them. Over the last months I have seen twice with this type of carburettor that one of the air correction jets was spontaneously broken (nearly at the top of them). The result is what you have described.
harley95
Posted - 17 Apr 2015 :  08:02:49  Show Profile  Reply with Quote
Originally Posted - 17 Apr 2015 : 20:08:19
The problem with my 64 Rapier has now been sorted thanks for the help
jbailey
jbailey
jbailey
