 Crank pulley
Posted - 29 Oct 2010 :  23:24:57  Show Profile  Reply with Quote
Hey
I have just managed to get hold of a replacement crank pulley, but before i go ahead and change it over i just want to check.
Do i need to use any special tools or methods, or am i ok to just unbolt - remove and bolt.
cheers
Posted - 30 Oct 2010 :  20:11:16  Show Profile  Visit 1922's Homepage  Reply with Quote
All I've ever used is a socket and ratchet and sometimes someone to sit in the car with their foot on the brake.
If you've go to do the job on your own - put the car in 4th gear and pull the hand brake on hard. With a bit of luck the pulley bolt will come loose before the car moves - if not you'll find yourself moving slowly backwards across the garage as you turn the engine over with the spanner
Edited by - 1922 on 31 Oct 2010 12:19:08
Posted - 01 Nov 2010 :  18:45:34  Show Profile  Reply with Quote
Thank you
Must say that doesnt fill me with confidence - possibly a job for my local garage i think.
Posted - 02 Nov 2010 :  19:22:18  Show Profile  Visit 1922's Homepage  Reply with Quote
Maybe - the other problem is that your socket set might not contain a socket big enough to fit the crank pulley bolt. I had to buy one specially - can't remember the size but it's a bit over an inch (1 and quarter maybe?).
With the right tools and if the woodruff key isn't damaged (they are usually ok) it's a ten or fifteen minute job.
Edited by - 1922 on 02 Nov 2010 19:35:29
