 Finally gone live!!
Posted - 10 Aug 2011 :  16:54:55  Show Profile  Reply with Quote
After the best part of 12 years I have finally got my SIV restoration to the point where I plucked up courage to connect the battery.I've gone to negative earth with an alternator,removed the control box,fitted relays for improved headlights,fitted a new battery and a 10 bank spade fuse box.
Nothing spectacular happened phew!
I've found a few small glitches and the starter will not engage (just spins)I did check it before re-fitting and the brushes etc all seem good,so a bit more investigation is needed.
I'll sort out some photos of progress and post them soon.
Regards to all
Posted - 11 Aug 2011 :  06:23:16  Show Profile  Reply with Quote
! we wanna see them...
If you have the invertor type starter it is probably the bendix that is sticky or faulty, easy to strip , or the solonoid is faulty on the other type starter .
Jan.
