1053 Posts |
Posted - 04 May 2013 : 19:38:46
I believe all will work. I tend to try and fit the ones with the little by-pass valve. More a case of if you want engine to run a little hotter or cooler. I think on the sender it is the one with the red band that is correct for the 1725 engine, but all this from memory that's not as good as it was!  |
